umuhire
Programming a Flash memory over PCIe for Artix 7
Dear community, I have read the Application note (XAPP518) regarding an In-system programming of BPI PROM using PCIe. It seems to be only appliable to Virtex-6, Virtex-7 and Kintex 7. How about the Artix 7? Thank you, Regards, Angélique
iguo
PCIe port of A7 is different so you will need to write your own code for this part.
The high level programming strategy would be no difference.
iguo
