krn-krn
QSPI-Flash programming
Hi.
We are using XC7Z14SCLG484-2 ZYNQ ,How to program the QSPI-Flash which is of 1GB,the flash part no:-IS37SML01G1LLI,And the vivado tool version is 2017.4.
is this flash compatible?
bhall0107
Hi @krn-krn,
Take a look at this document pages 361-375:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug908-vivado-programming-debugging.pdf
I couldn't find which family your specific ZYNQ belongs to, but I'm sure you can figure it out from here. It doesn't look like your specific flash is supported, but I could be missing something. Good luck and let us know what you find!
Brad
krn-krn
We are using Artix-7(zynq-7000).
bhall0107
I see. As you probably saw, it doesn't look like it's supported in 2017.4.
Maybe you could check other versions of Vivado to see if it's supported there.
Please don't forget to mark replies as an accepted solution if they helped answer your question!
Brad
