Regarding delay of cs after SPI transfer
I am using artix 7 FPGA I am using  BSP in SDK for Spi data transfer it is taking 2us for CS to go high after data trasmission can i reduce the the delay i have also attached the image and have shown delay b/n them it is around 1.6us can i reduce the delay
Re: Regarding delay of cs after SPI transfer
Hello @prashanth_makam
Typically, when Chip Select (CS) pin is asserted for particular SPI flash, that SPI flash is available for use with FPGA / uC.
Flash vendor provides Setup, Hold and deselect time details of CS. For example: please check Micron M25P16 datasheet : Table 21: AC Specifications and Figure 25: Serial Input Timing.
I will recommend you to go through datasheet of your flash and accordingly change CS timings accordingly.
I hope this information helps.
Bhushan
Actually I am asking for the SPI transfer and not regarding flash iam using manual chip select in the SPI
what chip are you driving ?
   do a quick check that you are also driving the cs pin 1 to 0, not Z to 0.
Iam doing from 1 to 0
