SPI NOR FLASH MT25Q not listed in Impact 14.7
Hi everyone,
I'm currently working with this Flash memory  MT25QL128ABA  which is the memory family of Micron. I was going to program the Flash memory using Impact 14.7 but I was not able to select the appropriate memory because it is not listed in the software.
Based on Micron supported memory, MT25Q 128Mb is supported in ISE 14.7 by selecting N25Q128 in iMPACT, but It is not listed in the software.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjJuf2rgfHWAhVB7yYKHTZQBL8QFggnMAA&url=https%3A%2F%2Fwww.micron.com%2F~%2Fmedia%2Fdocuments%2Fproducts%2Fother-documents%2Fxilinx_compatibility_guide.pdf&usg=AOv...
How can I program this memory using the software 14.7, in the FPGA virtex-5?
Re: SPI NOR FLASH MT25Q not listed in Impact 14.7
Hello @alebermudez94,
You can try programming the device by selecting M25P128 and skip id code check workaround.
How to skip ID code check
Following is the snapshot showing how the skip idcode environment variable has to be applied for impact tool
After setting up this please try programming the flash.
Please give us feedback about this.
Thank you.
Thank you.
Hi @kvasantr
Thanks a lot for your support.
I was able to program the flash memory MT25Q using M25P128 that is listed.
Newbie isela
Can this be done in Vivado ?
Itsik
isra-juk@zahav.net.il
