Serial Vector Format (SVF) File Programming for Zynq
I would like to create svf file offline on Zynq component. For that, I used the documentation ug908-vivado-programming-debugging.pdf chapter 8. However, at the end of process, I have an error which said "Flash programming using SVF is not supported for Zynq Devices".
Do you know how I can do?
Best Regards
回复: Serial Vector Format (SVF) File Programming for Zynq
Hi @codelani.80
NO, you cant do this for Zynq.
As you would know the procedure for indirect programming for Zynq/MPSoC device is not same as the normal FPGA device.
Hence SVF generation for indirect programming is not supported for Zynq devices.
hi c,
Here is a non-official supported workaround:
1. Type the following command in the tcl console: "set_param labtools.enableSVF 1"
2. When enable SVF file generation, click the box "Create SVF Only (no program operations)"
See if it can work then.
Ivy
Hi Ivy,
I tried your workaround but it doesn't work. Please see the attachment.
In the attachment, you can see the Tcl Console, and the error popup.
Nicolas
Hello Ivy,
Did you see my answer?
Best Regards
Nicolas
Hello Ivy,
Best Regards
Nicolas
Hello everybody,
Someone can help me.
Best Regards
Nicolas
Hi @codelani.80
