Ultrascale+ Maximum Configuration Bank 0 input voltage
I am working on an Ultrascale+ design which is implementing Slave SelectMap for configuration. The master operates at 3.3V. Obviously we need to do level translation for many of the I/O which are used in the configuration process.
My question is: Is it safe to pull INIT_B and DONE pins to 3.3V when VCCO_0 operates on 1.8V? I cannot find the relevant specification for this in DS922.
I did find there is an absolute maximum input voltage rating, Vin, but it is only specified for HD and HP I/O banks, but Bank 0 is neither of those.
Re: Ultrascale+ Maximum Configuration Bank 0 input voltage
Hi @jsmithsrc,
INIT_B to a 4.7 kΩ pull-up resistor to VCCO_0 to ensure clean Low-to-High transitions. Done Pin will have default 10Kohm resistor.
I belive connecting to VCCO_0 = 1.8V is recommeded and safe. Your condition is not charectrized by Xilinx.
Deepak D N
Please reply or give kudo or mark it as an Accepted Solution.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Hi @jsmithsrc,
Bank 0 are dedicated, you cannot change INIT_B and DONE pin voltage alone and the IO stanadard is also fixed i.e LVCMOS. Bank 0 get voltage based on VCCO_0 applied and CFVBGS pin. Please follow default Pull up.
Hope this cleares your query.
Deepak D N
Deepak D N
Sorry I wasn't clear.
If VCCO_0 is 1.8V, can I have pullups on INIT_B and DONE to 3.3?
Hi @jsmithsrc,
Deepak D N
Deepak D N
