Unable to create an ace file.
Hi, I have been trying to configure my Virtex 4 ML 402 thru the compact flash card reader, for that I need to put an ACE file in the card, however I have been unable to convert the .bit file to an .ace file. I tried the cmd method as well, it just doesn't create the file. Is there another way to create a ace file? Or am I doing it wrong?
@taahaa Check this
http://www.xilinx.com/itp/xilinx10/isehelp/pp_p_process_generate_target_prom_ace_file.htm
-Pratham
@taahaa What impact version are you using? Can you give a try with 14.7? Did you try with GUI?
-Pratham
Hi, thanks for your response, I did not use impact, I tried to do it thru command prompt, by first creating a batch file. It runs without errors but doesn't give the .ace file.
Also, I don't know how to create it from the impact, could you please show me a tutorial on that? I will give it a shot now!
Thanks!
@taahaa Check this
-Pratham
@pratham thank you! I will update you in a while with the result :)
Hi again, The type of file is :WinRAR archive (.ace)
This is correct right? (Sorry I keep on asking stupid questions, just new to all this.)
@taahaa I didnt get your question.
-Pratham
@pratham I have managed to generate a .ace file successfully. Thank you so much for all your help.
However, if you could lend me your assistance again please? I am unable to load the ace file in the FPGA. I have formatted the CF card and inserted the ace file in it along with xilinx system file, but when i plug in the fpga it shows the red led. Any suggestions?
