Visitor pulkit.vlsi
Vivado 16 on Windows 10 64 bit DLC9 USB cable issue
I have installed vivado 16 on windows 10 64 bit system.
Now i am trying to connect Xilinx USB cable DLC9G and it is showing error, "USB device is not recogniozed".
Please help.
Thanks in advance.
Scholar dpaul24
Re: Vivado 16 on Windows 10 64 bit DLC9 USB cable issue
@pulkit.vlsi,
Which FPGA/Development Board are you using?
FPGA enthusiast!
All PMs will be ignored
Hi @pulkit.vlsi
You can try following procedure for Platform cable USB II to work under Windows 10 environment:
1. Connect cable to PC/Laptop.
2. In device manager if cable is detected then uninstall and delete driver of cable.
3. Now after connecting cable, it should show unidentified device.
4. Remove platform USB cable
5. Navigate to "C:\Xilinx\14.7\ISE_DS\common\bin\nt64" for 64-bit installs or "C:\Xilinx\14.7\ISE_DS\common\bin\\nt" on 32-bit installs.(using Command Prompt in administrator mode)
6. Run wdreg -compat -inf %cd%\windrvr6.inf uninstall
7. Run wdreg -compat -inf %cd%\windrvr6.inf install
8. Connect the Xilinx USB cable.
Also take look at https://www.xilinx.com/support/answers/44397.html and https://www.xilinx.com/support/answers/54381.html
Bhushan
Bhushan
Teacher drjohnsmith
@bpatil
you mention the links to an ISE folder,
the poster mentions vivado ? are you saying ISE and Vivado use the same ?
Hi @drjohnsmith and @pulkit.vlsi
Oh!!!
Navigate to <Vivado Install Directory>\data\xicom\cable_drivers\nt64\\nt64 and run install_drivers_wrapper.bat
If above method does not work then, Perform all steps provided below for installing driver in Vivado:
  1. Make sure Platform Cable USB is unplugged
  2. Open a Windows cmd.exe prompt as Administrator
  3. In a command prompt browse to " <Vivado Install Directory>\data\xicom\cable_drivers\nt64\dlc10_win7"
  4. To uninstall type the command: wdreg -compat -inf %cd%\windrvr6.inf uninstall
  5. To uninstall type the command:  wdreg -compat -inf %cd%\xusbdrvr.inf uninstall
  6. Run command: net stop XilinxPC4Driver
  7. Delete with command: %WINDIR%\system32\drivers\windrvr6.sys
  8. Delete with command: %WINDIR%\system32\drivers\xusb*.sys
  9. Delete with command: %WINDIR%\system32\drivers\xpc4drvr.sys
  10. To reinstall type the command: wdreg -compat -inf %cd%\windrvr6.inf install
  11. Plug in USB cable
  12. Go to Windows Device Manager. Look for 'Jungo'. Make sure it says 'WinDriver' under Jungo
If not, right-click and select 'Update Driver Software'.  Select 'Search automatically for updated driver software'
  1. Go back to CMD prompt (With plugged in USB cable)
  2. To reinstall type the command: wdreg -compat -inf %cd%\xusbdrvr.inf install
  3. Programmer status light should turn on and be green, if attached to target
  4. Run 'Cable Auto Connect' to verify
Bhushan
Bhushan
