Observer jhabril
WARNING:iMPACT:923 - Can not find cable, check cable setup !
Windows 7 Home Premium 64 bits
I'm using iMPACT 14.7 and a VIRTEX-II PRO XC2VP30.
USB embedded JTAG CONFIG
USB regulars cable.
I tried the six solutions, listened in http://www.xilinx.com/support/answers/30184.html
Tree weeks whit this error.
No support from xilinx and no access to service portal.
Great product really bad support.
Observer jhabril
Re: WARNING:iMPACT:923 - Can not find cable, check cable setup !
Solution: iMPACT 10.1
Hi @jhabril
Try out these steps:
1. Open impact in 32-bit mode and try connecting the board (Start --> All Programs --> Xilinx Design Tools --> ISE Design Suite 14.7 --> Accessories --> ISE 32-bit Command Pompt --> run the command "impact" to invoke GUI)
2. Is drivers installed properly? Are you able to see the cable drivers in Device Manager window?
3. Did you try the same cable with any other machine and board?
Vinay
Observer jhabril
Hi @vuppala
1. iMPACT 32 bits, PROGRESS_END - End Operation.
Elapsed time = 2 sec.
Cable autodetection failed.
3.Three different cables (and different cable’s length) two different boards.
4. Geeting crazy 3 weeks whit this error.
5. Thanks a lot.
Observer jhabril
Visitor ulian
fixed!
In my case, the board had a different name,
All the drivers were installed automatically by windows. so,
Uninstalled it: properties ->Driver->Uninstal Device (advances)
Installed fresh driver "CP210x_Universal_Windows_Driver" from:
https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
done
System info: Win10 64bit, i7 16gb ram
Newbie n.mahdion
I had this problem. When I searched, I found that it is caused by a specific driver on my windows 7.  Please check that the driver with the name of WinDriver (you can find it in: "on windows OS, my computer>(right click) Properties>Divice Manager> Jungo>WinDriver) is correctly installed on your windows.
In my case, because of my windows was from 2013, firstly I updated it and installed related drivers and then installed ISE on my new windows. After that, I checked and observed that "Jungo>WinDriver" is properly installed.  Fortunately, it worked and now I could config my FPGA.
