jg_spitfire
Wrong voltage in SPI MOSI pin - myir zturn board zynq 7020
Hi, I am doing an SPI test with the myir board zynq7020 and when I connect the oscilloscope I see my CLK signal at 3.3V approx (yellow signal) but the MOSI pin is 4.8V (purple signal), I don´t have any other hardware connected to the board I just measuring the pins I have configured as SPI, maybe I am missing some config?, thanks, the CLK signal is at 20MHz
bruce_karaffa
What voltage is powering the device the SPI is connected to?  Is the MOSI pin pulled up to 5V on the schematic?  Are your scope probes grounded?  What is the bandwidth of your scope and probes?
jg_spitfire
@bruce_karaffa
"I don´t have any other hardware connected to the board I am just measuring the pins I have configured as SPI", I am measuring directly pin Y9 (MOSI)  and T9 (clk)
no, this is the board schematic
yes
300MHz
MattC1
Did you get the SPI working on the zturn board? I've been trying by connecting SPI directly to MIO or routing to EMIO and always get connection timed out errors.
