Laicheng
XCF32PFSG48C
Hello, I would like to ask if XCF32PFSG48C is ROHS 2015/863 compliant? Is there any exemption applicable to this part? Thanks
ddn
Hi @Laicheng ,
The " G" indicated that this part is ROHS compliant right?
>> Yes, its ROHS Compliant.
May I know is it referring to ROHS 2015/863 as well?
>> Yes. refer this https://www.xilinx.com/publications/prod_mktg/quality/xilinx_rohs_statement_eu-directive-2015-863.pdf
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
ddn
Hi @Laicheng ,
Refer this AR#15023 which will help you.
Deepak D N
Laicheng
The " G" indicated that this part is ROHS compliant right? May I know is it referring to ROHS 2015/863 as well?
ddn
Hi @Laicheng ,
Deepak D N
Laicheng
Thanks for your reply. It helps a lot. Have a great day!
