Xilinx xc5vfx70t
I hope to find the library file or CAD file about the chip xc5vfx70t-665, which can be opened directly on the AD and the pin information is clear.
https://www.xilinx.com/support/answers/66757.html
Check the instruction guide of the PCB tool you are using.
We don't provide the schematic library for a very very long time. You need to use the .txt format pinlist file to create by yourself.
Thank you for your reply,
Can you please tell me how to do this? If you have a detailed tutorial, it would be great.
