hello_will
ZYNQ 7010 ENET Configuration
I want to initialize a 100M network port and configure it as follows:
The final configuration result is as follows
which is different from others configured as follows:
There are a few more interfaces, such as:ENET0_GMII_TX_ER、ENET0_GMII_COL、ENET0_GMII_CRS、ENET0_GMII_RX_ER;How did they remove these ports?
salvo
Hi hello_will,
i'm testing for the first time the ethernet and during settings of the PS i had the same result of your images. Did you test it anyway?
Salvo.
salvo
Hi again,
i think that it's just that the other interfaces are simply hidden, but it is exactly the same! In the picture there is the '+' next to GMII_ETHERNET_0, in our case there i the '-'.
