bit-stream encryption and updatemem (Series 7 and US)
We need to add BRAM (probably only a single BRAM) initialization to post-implementation design (no processors, just logic).
The final bit-stream must be encrypted.
Is there a recommended or possible way to do this?
i.e. could the merge be done on the clear bit-stream and then encrypt the resulting bit-stream?
David
