'boot_hw_device' failed due to earlier errors.
I have a problem with loading my Zynq device from the configuration device.
After a power cycle the FPGA loads correctly, but it cannot be loaded by the Vivado command: boot_hw_device. (Right-click in Hardware Manager on the device -> Boot from configuration memory device)
boot_hw_device  [lindex [get_hw_devices xc7z030_8] 0]
INFO: [Labtoolstcl 44-664] Will wait up to 180 seconds for booting to complete.
ERROR: [Xicom 50-56] Error getting stream information for target node .
ERROR: [Labtools 27-2254] Booting from configuration memory device unsuccessful.
ERROR: [Common 17-39] 'boot_hw_device' failed due to earlier errors.
(I want to say again that the device can load after a power cycle, so it is not seem as a HW issue. And my Kintex-US can load with the boot_hw_device command, on the same JTAG chain.)
I use:
  • Vivado 2017.4
  • Win 10.0.19041 Build 19041
  • Zynq 7000 (xc7z030)
