breaking SelectMAP transmission
Hi all,
I am doing readback data on SelectMAP or ICAP in correct sequence (as stated in UG360 Table 7-2) :
write - > reading data -> write. And everything is ok.
Be specific : Virtex 6 needs dummy and 81 dwords per frame to be read.
My question is : Can i break transmission earler in reading phase on interface ? I am thinking of two scenarios :
1. read as many dwords as i need and try to initiate another transmission (without ending current transmission)
2. read as many dwords as i need , write ending sequence on interface and try to initiate another transmission.
I have done some research and what can be seen is that after first break transmission :
second transmission can not be done due to ICAP_BUSY signal asserted :
I wonder if there is any command I can issue on interface to reset SelectMAP FSM or something like that.
Thanks for any advise !
Lukas
Hi All,
I am trying to perform readback capture on VCU118 (XCVU9P).
I do that through ICAP by the use of embedded logic.
I am quite familiar with this process through Virtex5/6.
My observations on US+ are:
  1. issuing SHUTDOWN command - causes implementation to hang-out
what exactly do SHUTDOWN command (there is no way to get to know this from UG's) and is it necessary to perform readback capture ???
if I omitt SHUTDOWN command - performing reading from configuration memory doesn't hang the implementation
2. In the readback capture without issuing SHUTDOWN reading from particular address for seeking for a bit indicated in .ll file(Logic Location file) - frame address and offset, it seems to the bitstream doesn't correspond to registers values I know well and have possibility to change their states. I am preety sure that I am reading exactly bit of interest (use Chipscope)
I know there is different way in US+ to perform Capture CTL/MSK regs but it seems like it don't work.
are there any other factors (xdc attributes) that can influence mismatch between readback bitstream and Logic Location file ?
I know XAPP1230 and the way of performing readback via JTAG and reading whole configuration memory rather than particular frame.
Is ICAP in some kind of way defective for that purpose?
I keep MCAP disable.
Reading for example in that way IDCODE returns perfect value
please answear if someone is interested in this topic.
we can do further investigation .
thanks
Łukasz Matoga
