link needed for vivado basic programming
    i have some basic knowledge to work with spartan 6,verilog & Xilinx 14.7. now i installed Vivado 2019.1.1 and i have Kintex 7 kc705 development board and vertex 7 . dont know where to start with ... any example codes /links are there?
Thanks in advance
Hi @bosechandran ,
Check this tutorial: ug888
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
