maximum .bit File size in xczu9cg (Zynq ultrascale+mpsoc)
Does anyone  know the maximum size of the .bit file generated for xczu9cg (Zynq ultrascale + mpsoc).
Thanks in Advance.
Ashokkumar R
Re: maximum .bit File size in xczu9cg (Zynq ultrascale+mpsoc)
It could be about 26.6 MB if you enable the Per Frame CRC feature.
Scholar u4223374
The bitstream length is in UG1085, Table 11-10. For the ZU9 it's just over 24MB (the table lists it in bits). That's the longest bitstream you'll ever see; if you enable compression it might get smaller.
