name of state in state machine
Hello, I have a question of nominating the states in a fsm in vhdl.Is there any benefit to name the states as " 000,001,010,100..." compare to "a,b,c,d..."?
Usually in VHDL you use an enumerated type for state machines
type stat_t is (idle, s_do_something, s_do_something_else);
In VHDL this has no inherent bitwise value. But Vivado then gets to chose the encoding based on synthesis settings.
@ame,
That's pretty vague as a question but I'll try and help.
Here's what I do in systemverilog:
typedef enum logic [2:0] {IDLE,  START, RUN, MOVE, DONE } cap_state_t;
Then you can use IDLE, START etc were you would use 3'b0, 3'b1.... etc.
Much better to use enumerated types - as you know, inherently what the state is.
Your code becomes simpler and readable. Maintenance / changes are easier.
Jerry
thank you for your response.If I understand well, you give each state name(such as "IDLE") a vector (as "000") to make sure a stable change between each state.But in VHDL, I find that when define a group of state names, they don't give value, just as different names, so I propose this question: whether use string names (one, two, three,four)or directly with array of number like "one hot"(000,001,010,100)
Thank you, I understand
