Visitor jcon
.nky key file not getting generated with Vivado 2018.2
I have applied the following constraints:
set_property BITSTREAM.ENCRYPTION.ENCRYPT YES [current_design]
set_property BITSTREAM.ENCRYPTION.ENCRYPTKEYSELECT BBRAM [current_design]
set_property BITSTREAM.ENCRYPTION.KEY0 256'hxxxxxxxxxxxxxx [current_design]
set_property BITSTREAM.ENCRYPTION.STARTIV0 32'hyyyyyyyy [current_design]
After running the "write_bitstream" command, I observed that the .nky file is not getting generated.
This issue is only observed after moving to vivado2018.2
With the same constraints mentioned above, there were no such issues in 2016.2 and 2017.3 versions.
What is the reason for this?
Re: .nky key file not getting generated with Vivado 2018.2
To work around this issue, create the .nky file manually, or using another tool. This issue has been fixed in Vivado 2018.3 and the correct second.nky file is generated.
Check out this AR for more information:
https://www.xilinx.com/support/answers/72420.html
Ebrahim
Visitor jcon
I tried the same with vivado 2018.3, but its still not generating the .nky keyfile.
Based on your reply, which other tool are you suggesting that I use?
