chanhow
set start address
Hi.
 I can set the start address when I create the configuration file.
 then, is there any way to set the start address hardware?
antti-lukats
yes you pulse PROG_B and it sets address to 0!
hj
Once you load the MCS file multiboot settings, the configuration engine will jump to the required address if IPROG is enabled in the design and load the multiboot image.
If this fails and fallback is enabled then it will fallback to the image kept at address 0. Refer to XAPP1247 or UG470. https://www.xilinx.com/support/documentation/application_notes/xapp1247-multiboot-spi.pdf
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
