pzy
some questions about the frame addressing of virtex-5 FPGAs
I want to read back the configuration frames from XC5VFX130 FPGA through an internal port and compare them with that stored in radiation-hardened memory to detect and correct SEUs. I have read the ‘Virtex-5 FPGA Configuration User Guide’ (UG191) and these are my questions:
Question one: From a configuration point of view, I draw the virtex-5 FPGA fabric according to the figure6-11 and figure6-12 in UG191(page 131,132 in UG191).
The virtex-5 FPGA fabric drew by myself is shown in fig.1.
Fig.1 virtex-5FPGA fabric
 Is it correct? I think it is wrong. Because it’s described in the UG191 that a row consists of a stack of basic blocks (20 CLBs, 40 IOBs, 4 block RAMs, etc.)(page 129 in UG191).
But a row only have 2CLBs,2IOBs,3block RAMs,1DSP in figure6-12(page 132 in UG191).I don’t know why, and I want to know the complete structure of a row.
Question two:It’s described in the UG191 that the largest Virtex-5 device has a total of 12 rows(6 in each half).But my device is XC5VFX130 FPGA and I want to know how many rows in each half.
this is the link of UG191:http://www.xilinx.com/support/documentation/user_guides/ug191.pdf
Thanks in advance:)
thanh_nguyen
I have the same question.
Do you have an answer?
Anyone else can help, please?
iguo
Hi Guys,
This is kind of sensitive information. A clue for you is to check the device view in PlanAhead.
Not sure why you need to get the detailed structure of FPGA but if you plan to do scrubbing, find some material talking about Scrubbing and contact your local support.
Ivy
