startup primitive default setting connection
The Ultrascale Kintex PCIe core has a block of signal from the STARTUP Primitive that are input which I need to tie high or low. They show up from the pcie3_ultrascale_0.vho
These signals appear on the pcie_ultrascale component when the Tandem feature is selected from the wizard.
PG156 doesn't describe how to connect them in my instantiation instance. The list of input signal are shown below. What document describe the condition or state required to connect them properly if I don't need them.
--    startup_do => startup_do,
--    startup_dts => startup_dts,
--    startup_fcsbo => startup_fcsbo,
--    startup_fcsbts => startup_fcsbts,
--    startup_gsr => startup_gsr,
--    startup_gts => startup_gts,
--    startup_keyclearb => startup_keyclearb,
--    startup_pack => startup_pack,
--    startup_usrcclko => startup_usrcclko,
--    startup_usrcclkts => startup_usrcclkts,
--    startup_usrdoneo => startup_usrdoneo,
--    startup_usrdonets => startup_usrdonets,
回复: startup primitive default setting connection
Hi @tchin123
Please refer to table 7-11,Pin Descriptions in ug570:
http://www.xilinx.com/support/documentation/user_guides/ug570-ultrascale-configuration.pdf
Simon
Hi @tchin123
Simon
