vivado 2018.3 Write Memory Configuration
Hi all.
I want to create mcs file.
At that time, I can not change the save location.
How to change the save location?
Please help me.
Thanks all.
Sorry,Self-solved.
"・・・"click can changed.
Sorry,Self-solved.
Hi @bzreit
I believe your issue is resolved. Could you please close this thread by the post as accepted solution.
Rohit
