hrmt
voltage on pins when input and powerup
Hi everybody
i have an xc2c1287vqg100c cpld. when device power up voltage pins are high(before programming) but i have want that be low(before cpld programming).
what should i do?
u4223374
Advisor
Advisor
There shouldn't be any time after powerup and before programming on a CPLD; it programs itself from the internal memory as it powers-up. Unlike an FPGA, there is no "power on reset" state for the chip unless you explicitly program one.
u4223374
Advisor
Advisor
hrmt
Hi @u4223374, thank you so much.
