2015.3 7 Series/Zynq-2000 XPE with Excel 2010 -- PS sheet does not appear.
Hi all,
I'm using the 2015.3 version of the Xilinx Power Estimator spreadsheet and I am having issues when I specify a Zynq part. The PS tab does not appear as expected. When I select between Zynq and non-Zynq parts, the summary page does change to disable/enable the PL/PS items, but the "Jump To Sheet" buttons are blanked out. When I select between a Zynq part that supports GTX transceivers and one that only supports GTP transceivers, the GTP sheet remains. It seems that the code that selects the visibility of the various sheets depending on the part is broken.
Everything else seems to work but I cannot enter any PS-related data. Has anybody else encountered this issue?
Jerome Gobuyan
Re: 2015.3 7 Series/Zynq-2000 XPE with Excel 2010 -- PS sheet does not appear.
Hello @jerome.gobuyan,
Have you confirmed that your excel settings allow macro executions? Please check page #7 from below UG
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug440-xilinx-power-estimator.pdf
Here are some ARs which can be helpful
http://www.xilinx.com/support/answers/63237.html
http://www.xilinx.com/support/answers/63366.html
Ashish
Macros are enabled and everything else works. I found and tried the 2014.3 version and that works fine. None of the 2015 versions worked.
I tried this again with the 2016.1 version of the spreadsheet. I have the exact same problem.
Jerome
@jerome.gobuyan Its strange that you noticing this issue across multiple versions.
Can you share the OS and Office version you using?
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
I'm using Windows 8.1 and Excel Office Home and Business 2010.
The 2014.3 version definitely works for me.
Jerome
Visitor doever
I am using Windows 7, Excel 2007. Macros enabled. XPE 2016.2 and I have the same issue. When selecting the Zynq part, the PS Sheet does not appear. Also, the Quick Estimate button errors out when executed.
I will try and find version 2014.3
