Visitor krbvroc1
2016.3 Documentation Navigator ERROR
I upgraded to 2016.3 (Linux). When I use the Documentation Navigator and select Download Manager to download new documentation, it fails to load 49 documents. However if I select a single document and click Open Document, it loads the same exact URL in my browser. So it would appear something with the Download Manager is not working with 2016.3 and I would obviously prefer not to have to download everything individually.
Visitor krbvroc1
Re: 2016.3 Documentation Navigator ERROR
krbvroc1 wrote:
So it appears all the files in the catalog that get downloaded to the xilinx2016_3 directory are listed in the catalog with a https URL. All other documents are simply http. Maybe a missing dependency or something introduced with 2016.3
Installing the 32-bit version of openssl-libs fixed this problem.
check these links
https://www.xilinx.com/support/download.html
http://www.xilinx.com/video/support/how-to-use-document-navigator.html
Thanks and Regards
Balkrishan
Visitor krbvroc1
I don't understand the point of your generic response. I already know how to use the Documentation Navigator - I am reporting that there appears to be a problem with version 2016.3. There is a bunch of documentation marked to be downloaded for 2016.3 and they all fail with an error in the download manager. See screenshot below. However if I go back to the catalog and select one of the guides that fails, right click open document, it launches in my PDF reader. So it is something wrong with the bulk download process via the 2016.3 download manager. This worked fine for me last week with 2016.2.
Visitor krbvroc1
Running docnav by hand in a terminal to see the console output yields the following clue:
For each failed file:
QSslSocket: cannot call unresolved function SSLv23_client_method
QSslSocket: cannot call unresolved function SSL_CTX_new
QSslSocket: cannot call unresolved function SSL_library_init
QSslSocket: cannot call unresolved function ERR_get_error
Visitor krbvroc1
Newbie david0dl
Seems thatthere was a breakage between openssl and the libssl-dev (Debian/Ubuntu and others), or compat-openssl10-devel (Fedora)...
Here they indicate the solution for several OSes:
https://github.com/wkhtmltopdf/wkhtmltopdf/issues/3001
