At what frequency will the unit run, either of Microblaze or FPGA or Bus architecture?
I am working on a project of a custom IP for a logic adder. This custom IP is added to a project in XPS containing Microblaze in PLB architecture. I want to know at what frequency the output is generated or the system is running to generate the output, either at a clock speed of bus architecture or of soft processor or of FPGA clock speed?
Thanks in advance!
