Anonymous
Not applicable
Atmel dataflash page size?
For ATMEL dataflash such as AT45DB161D, there are 2 types of page size( 512 or 528 bytes per page).
When used as "serial spi configuration mode", which value used when indirectly programing SPI with IMPACT though fpga?
And which value to be used when configuration from spi flash after power up?
My fpga is xc3s500e-pq208, and ise/edk version is 10.1.3.
Anonymous
Not applicable
Why? No one reply this question?
scrts
It is possible to select page size. AFAIK factory programmed is 512 bytes/page. More instructions in datasheet: http://www.atmel.com/dyn/resources/prod_documents/doc3500.pdf
