Observer diegoroman17
Best practice with Clock divider in FPGA
Hi everyone,
I am beginning at the world of FPGA and the VHDL. I have wrote code in VHDL y tested with the basic concepts of FLIP-FLOPs, Models, Sequencies, FSMs, etc. Now I am viewing the manage Clock within FPGAs and I want test with a blink led. I have in my board a clock input signal of 40MHz and want divide this to 1Hz, 10Hz, etc. I have tried with Clocking Wizard but it does not posible because the frequency output is very small. I have thought do it with counters that divide my input clock, also I think in use the Clocking Wizard for divide my clock to 5Mhz and after to use counters. Exist various options for this task, my question is, which is the better option considering the performance, resources, etc, for do this task?
Tags (4)
Teacher eteam00
Re: Best practice with Clock divider in FPGA
In every design I have ever seen, the signal used as "clock" or "SCL" in an I2C channel is generated from a state machine running at some higher frequency with some other 'master' system clock.
For purposes of FPGA design, the SCL signal (as either input or output) is *not* a clock.  It is nothing more than a timing reference for the SDA (data) signal, for all the devices connected to the I2C channel.
When desiging FPGA logic, a clock signal is (generally speaking) a constantly running clock.  The SCL signal of an I2C controller interface is a clock in the context of I2C, but is simply another formed handshake signal in the context of FPGA logic design.
-- Bob Elkind
SIGNATURE:
Summary:
Teacher eteam00
Use a multi-bit synchronous counter to divide the clock.  Then you can use either counter bits to directly drive the LEDs, or you can decode the counter bits to perform attention-getting functions (for example:  gradual cycling between dim and bright, a walking light pattern, etc.).
You should use (or need) only one clock.  All functions should be decoded from the counter bits.
-- Bob Elkind
SIGNATURE:
Summary:
Then, When is neccesary use the clocking wizard? and when is neccesary use a hybrid between cloking wizard and counters? Could give me any example, please?
Teacher eteam00
The Clocking Wizard is a user-friendly menu-driven interface for selecting clock generation circuitry (PLL, DLL), synthesis mode, input configuration and output configuration.  The result is a set of attributes attached to an instance of PLL or DLL or DCM which perform the functions you specify.
In other words, the Clocking Wizard simplifies the instantiation of a DCM/DLL/PLL clock generator.
The Clocking Wizard cannot provide features which are not realisable with the actual PLL/DLL/DCM.  Hence, clock division for the purposes of driving LEDs is *not* an intended Clocking Wizard function.
Is this the sort of answer for which you were looking?
-- Bob Elkind
SIGNATURE:
Summary:
Yes, This is the response, very good explanation. Thanks. Now I have other question over the same theme. Ok I understand that clocking wizard is not for driven a led, but if I want generate a clock of 400kHz for a logic system, for example I2C of low speed, how I can do it? Is correct do it with counters? the signal clock is correctly routed in high speed lines within FPGA with counters? Sorry for the questions, but I try understand the concepts in deep.
Teacher eteam00
-- Bob Elkind
SIGNATURE:
Summary:
Perfect. Now I understand a few more over Clock theme, but there is a large way for learn VHDL and FPGA. Thanks for help me Bob.
can u give me the report of that clock divider and also source code and testbench
