Observer camccarthy
CameraLink
I am attempting to instantiate the appropirate CameraLink IP for multiple different FPGAs within the same Verilog project. i am doing this by using an input parameter with the name of the component the user is trying to create a CameraLink interface for. An issue I am having is that, if a component is selected, the other code still exists in the project, and some FPGAs don't have certain parts as others do. For example, Spartan 6 parts use OSERDES2 for serialization while Virtex 6 uses OSERDESE1.
If I try to implement for say, Spartan 6, the code for Virtex 6 still exists in the project and gives me errors since the OSERDESE1 component does not exists in a Spartan 6 board. Is there a way I could glaze over the code or perhaps, another way to be doing this?
Thank you,
Cam.
Observer camccarthy
Re: CameraLink
Solved by using generate statements
Observer camccarthy
Re: CameraLink
