Cannot Download Vivado 2017.2
Currently I am using Vivado 2015.2. I am trying to download 2017.2  One signs in. Then downloads. Then a popup asks you to sign in again. Then after you're done selecting all of the components another popup appears and asks you to sign in. But here is where it stops. It doesn't go any further. You sign in and the popup just popups again.
Anyone know the solution?
Re: Cannot Download Vivado 2017.2
I had to download the image. Took 5 hours. Unzipping took 15 minutes . Installation took 1 hour.
Hey @swimteam,
Make sure that your computers clock is accurate (if possible use ntp to synchronize).
Hope this helps,
Herbert
There's nothing wrong with the clock.
I presume you are encountering this with the Web-Installer ...
...if so, did you try the Single-File Download?
Best,
Herbert
