upal_fast
ERROR:LIT:407 - CI of CARRY4 symbol "<inst>" must be driven by another CARRY4 component.
Hello
          I am using ISE 12.3 to simulate my design,the device family is virtex 6.I got this error while mapping my design -                ERROR:LIT:407 - CI of CARRY4 symbol "<inst>" must be driven by another CARRY4 component.
      When i looked for it in Xilinx i got a link - http://www.xilinx.com/support/answers/30112.htm where this error and its solution   is given.
     I am using Linux(Fedora - 11) as my platform.As mentioned in the solution i tried to set the environment using setenv XIL_MAP_OLD_SAVE 1 command in the root command prompt.After that i used echo $XIL_MAP_OLD_SAVE to check the result.The env was set.I restarted ise, but still when i am trying to map my design i am getting the same error.
    Is there any other way to get rid of this error.
   Any advice will be of great help.
Thanks in advance.
erpiyank
I'm also having the same problem with ISE10.1.03. Did you get closure on this issue. $XIL_MAP_OLD_SAVE is set to 1 in my case as well. But I'm still getting the problem in mapping.
I'm tieing off CI to 1'b0 and CYINIT is connected to input port of the module.
LIT:407 -CI of CARRY4 symbol "physical_group_carry_del0/del0" must be driven by another CARRY4 component.
