Newbie kakumaku23
ERROR:Xst:528
I am having trouble synthesizing my verilog code for a finite state machine, so I can program it onto a Basys-2 board.
Here is the verilog code:
module hwten(clock, clear, w, z);
input clock, clear, w;
output z;
reg [1:0] p, Y;
parameter [1:0] A = 2'b00, B = 2'b01, C = 2'b10;
always @(w,p)
case(p)
A: if (w) Y = B;
else Y = A;
B: if (w) Y = C;
else Y = A;
C: if (w) Y = C;
else Y = A;
default: Y = 2'bxx;
endcase
always @(negedge clear)
if (clear == 0) p = A;
always @(posedge clock)
p = Y;
assign z = (p==C);
endmodule
And here is the error that I'm getting:
ERROR:Xst:528 - Multi-source in Unit <hwten> on signal <z>; this signal is connected to multiple drivers.
Drivers are:
Output signal of FD instance <p_2>
Signal <p<2>> in Unit <hwten> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <hwten> on signal <p<1>>; this signal is connected to multiple drivers.
Drivers are:
Output signal of FD instance <p_1>
Signal <p<1>> in Unit <hwten> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <hwten> on signal <p<0>>; this signal is connected to multiple drivers.
Drivers are:
Output signal of FD instance <p_0>
Signal <p<0>> in Unit <hwten> is assigned to VCC
Thanks for any advice
Re: ERROR:Xst:528
You are assigning a value to the "p" in two different processes and this creates two drivers connected the same net which is not allowed.
You are attempting to create a register with and asynchronous load (not a reset) function.  Depending on the FPGA family that you are using it maybe possible to create an asynchronous load using preset and reset pins, but the code would be a bit complicated.  It is unlikely that your design really needs this functionality and instead using should be doing this synchronously
always @ (posedge clock)
begin
   if (clear == 0)
      p = A;
   else
      p = Y;
end
