FATAL_ERROR:Bitstream:stanbsbitfile.c:3408:1.57 - Incorrect number of bits in bitstream (18) for FDRI write
I hav built an Saprtan 6 project on ISE 14.5 in Windows 7 OS.....
Same project when I try to build on Windows 10 OS (another 64bit PC) with ISE 14.5 I am able to run till Place and route ..... While generating the Bit sream I get this error
""FATAL_ERROR:Bitstream:stanbsbitfile.c:3408:1.57 - Incorrect number of bits in bitstream (18) for FDRI write""
In My design I have added an ICON and ILA chipscope IPs.... If i comment this portion then I am able to build bitstream.....What could be the issue...
Please help
Re: FATAL_ERROR:Bitstream:stanbsbitfile.c:3408:1.57 - Incorrect number of bits in bitstream (18) for FDRI write
Now I am able to build the project
I changed the compatibility mode of WIndows 10 to a lower version and with this I could build the bit stream
@rakeshm55 I would recommend stick with supported OS i.e Windows 7. Please check similar thread discussion
https://forums.xilinx.com/t5/General-Technical-Discussion/Fatal-Error-in-bitgen-after-upgrading-project-to-ISE-14-7-from/td-p/456738
-Pratham
I have referred to the suggestions while trying to get license/open project .....
http://www.eevblog.com/forum/microcontrollers/guide-getting-xilinx-ise-to-work-with-windows-8-64-bit/
Many others claim that they are able to build projects  in ISE 14.5 with windows 10.....Though Xilinx offers no support for ISE for Windows 10 ....
I already have a PC which has upgraded windows 10.....where we have built projects on 1SE 14.5 for Artix 7
@rakeshm55,
Glad to know that you are now able to build the project. Please close the thread by marking the post as "Accept as solution" to help other users who could face such similar issue.
FYI: Please note that since ISE is in obsolete mode, I don’t think this will be later supported with Windows 10.
      However we do have roadmap to support Win 10 in our latest tool Vivado.
Syed
I too encountered the same error message on WIN10 with ISE 14.7. After is occurred I closed all apps.  I was able to successfully implement design and  generate the programming file. I did need to add a space and remove the space from a .v file and save it so the the process could be started.
Can you point to how you changed the compatibility mode of Windows 10? I am trying to run ISE in compatibility mode but I cannot, because ISE is a shell script not an executable. So "run in compatibility mode" does not show up as an option when I right-click on the ISE icon.
