wuchy143
FPGA Schematic Entry
Hi All,
I was wondering what the common tool that is used for FPGA schematic entry? I"m using pads 2007 and it doesn't have many bga's?
-mike
gszakacs
Instructor
Instructor
I'm using a very old version of ViewDraw for schematics and PADS layout for placement.  But I
always make my own symbols.  Over the years I've come not to trust anyone to do that for me.
If you want a schematic editor with more pre-built symbols, then Orcad probably is the most
popular.
By the way I also don't use vendor-provided decals or symbols for layout.  They rarely take
into account all of the layers and other settings used in the multilayer designs.
regards,
Gabor
-- Gabor
wuchy143
exactly what I was looking for. Thanks.
wuchy143
also.
I'm using a XC3S700A which has a 484 BGA. The datasheet doesn't use pin numbers. Instead they use D18, E17..etc. When I take my netlist into layout will this cause problems? Basically how does the layout tool know physically where each pin (D18, E17, etc) is physically on the PCB?
bassman59
Historian
Historian
@wuchy143 wrote:
also.
All reasonable modern PCB layout tools have no problems with alphanumeric pin numbers. If your chosen tool DOES have a problem, pester the vendor for an update or replace it!
mcgett
All Ball Grid Array devices use a letter (A-Z) for the row and a number for the column to indentify each ball location.
The PCB decal defines the mapping of each ball name to the physical XY location.  This is the same methodology used for any package type.
wuchy143
Thanks all
In looking at dev board schematics and talking to other FPGA board designers it appears that FPGA's are entered into the schematic using roughly 5 different blocks. Each block consisting of: Core voltage pins, i/o voltages, aux voltage....) Is this the standard way of doing the design? If so what are each of the common blocks that fpga's break down into??
-mike
gszakacs
Instructor
Instructor
When I make FPGA symbols the number of blocks depends on the pin count of the device.
I try to make as few blocks as possible while fitting my schematic page format.  When breaking
up the device I usually use banks as the minimum unseparable portion of the FPGA and
make sure that the bank Vcco is on the same symbol as the bank I/O's to make it clearer
how the bank is powered.  I have noticed that others tend to place all powers and grounds
on a separate block that is then placed on the power supply / decoupling schematic
page.  On larger devices I also have a block for the configuration and other logic that
doesn't fit within any bank, including the Vccaux power supply pins.  Normally I use
the top and bottom of each block symbol for Vccint and ground connections respectively.
Obviously a lot of this is a matter of preference, and whatever makes sense to you
from a readability point is the best way to do it.
-- Gabor
digisolve
Do you have a intall disk for ViewDraw? I have sone very old FPGA designs which were done in ViewDraw 7.2, but My client no long has the install CD
