Firmware for faster speedgrade
Hello!
If i've got working design for, say, Virtex5 -1 speedgrade, will the same binary file work correct in the same Virtex5, but -2 or -3 speedgrade?
Regards.
Dies diem docet.
Instructor
Instructor
Re: Firmware for faster speedgrade
If you are asking if synchronous designs work reliably on all speed grades of Virtex-5 devices - - up to a datasheet frequency limit --  the answer is yes, of course they do
-- Bob Elkind
SIGNATURE:
Summary:
Instructor
Instructor
The answer is, generally, YES.
Keep in mind that a -1 speed grade device may be faster than a -2 or -3 speed grade device.  The speed grade under which a Xilinx FPGA is sold means that the device has been tested to meet certain MINIMUM levels of performance.  The extent to which the device EXCEEDS this minimum level of performance is not tested or guaranteed, unless it is explicitly declared in the device datasheet (i.e. maximum propagation delay is often specified, but not minimum propagation delay).
This is one of the reasons that asynchronous design is a dodgy practice which is not supported by Xilinx.
-- Bob Elkind
SIGNATURE:
Summary:
Professor
Professor
Yes.
The minimum delay times used for all speed grades are based on the fastest speed grade.  So you won't suddenly end up with hold time errors with a faster speed grade part.  In addition, you should be aware that a part marked -1 could actually meet -2 or -3 speed, but was not tested to that speed grade.  As products mature, the percentage of product that meets the faster speed grade requirements goes up until at some point Xilinx needs to ship some faster product to meet demand for slower speed grade orders.
-- Gabor
Bob,
That "generally" bothers my mind :)
When I look into a timing report for two PVT corners, I see "fastest" and "slowest" delays for data and clock lines analyzed. I'm using synchronous design, without any hint of "undocumented tecniques", but:
Can I be absolutely sure, that if I've got tight design, that has ones of picoseconds margin in one of PVT corners - that margin will not be violated in another speedgrade device?
Can I be absolutely sure, that if "data" will come 10 ps earlier in another speedgrade - "clock" won't come another 10 ps earlier than "data"? :)
Thank you.
Dies diem docet.
Instructor
Instructor
-- Bob Elkind
SIGNATURE:
Summary:
Thank you both, Bob and Gabor.
Dies diem docet.
