guilvard
Generic instanciation of a module ?
I have a vhdl module i would like to instanciate several times.
In order to be able able to easaly change the number of module i would like this instanciation to be generic...
for i in 0 to Nb_elements generate uut : CLK_def PORT MAP ( Clk => Clk, Raz => Raz, Sig_A => Sig_A(i), Sig_B => Sig_B(i) ); end generate;
 Thank you for your help,
Alex
bassman59
Historian
Historian
That'll work; simply put Nb_elements in your entity's generic list.
Make sure that you use that generic to set the width of the Sig_A()  and Sig_B() vectors.
