Voyager
Voyager
How to compare timing reports as FPGA and ASIC technologies are different ?
Hi Friends,
ASIC and FPGA implemented technologies are different , then how we have to make sure proper timing analysis ?
NOTE: Any help or suggestions are highly appreciated ?
Thank You
S Sampath
-Sampath
s,
Are you prototyping an ASIC in a FPGA device?
If so, down load and read "FPGA Prototyping Methodology Manual" (Xilinx & Synopsys):
https://www.synopsys.com/company/resources/synopsys-press/fpga-based-prototyping-methodology-manual.html
The tool of fpga either quartus and vivado takes care of timing analysis. If required clock is need to be specified it is given in the constraints file.
