mitchherkert
How to implement an inverter bubble in ISE?
Is there a way to use just a bubble inverter in ISE? Currently I am using buffers with an inverter on my inputs, but I would rather just put a bubble on the gates in order to have 4 inputs instead of 8. Thanks.
htsvn
You can use them in schematics.
Refer to page 54 of http://www.xilinx.com/itp/xilinx10/books/docs/virtex5_scm/virtex5_scm.pdf
--Hem
htsvn
--Hem
