gjacques
IBUFDS Attributes
For the IBUFDS attribute DIFF_TERM, what represents FPGA internal differential termination used (TRUE or FALSE)?
eteam00
Instructor
Instructor
This is a mess!!
If you look in the Spartan-6 SelectIO User Guide UG381 (v1.4), page 23, it is mostly clear that "DIFF_TERM=TRUE" means 'yes, include input termination'.  Sadly, if you look at theSpartan-6 Libraries Guide for HDL UG615 (v12.4), page 118 "DIFF_TERM" does not appear in the list of available attributes for IBUFDS.  But DIFF_TERM does appear in the Verilog and VHDL example templates.
That's mess #1.
If you look in the Virtex 6 SelectIO User Guide UG361 (v1.3), page 32, it is mostly clear that "DIFF_TERM=TRUE" means 'yes, include input termination'.  Sadly, if your look at the Virtex-6 Libraries Guide for HDL UG623 (v13.1), page 151 "DIFF_TERM" does not appear in the list of available attributes for IBUFDS.  But DIFF_TERM does appear in the Verilog and VHDL example templates.
That's mess #2.
Bottom line:  "DIFF_TERM=TRUE" means 'yes, include input termination'.
Bottom line #2:  Just because you find an answer in one doc does not mean you can stop looking for another answer to the same question.  Sigh....
This probably warrants a webcase and a CR.
UPDATE:  I've opened webcase # 876157, referencing this thread.
-- Bob Elkind
SIGNATURE:
Summary:
gjacques
Thanks, I spent at least 2 hours searching for the answer and I could not find a single Xilinx document for any Silicon part that explicitly defined DIFF_TERM attibute TRUE/FALSE.  I too have opened a web case.
eteam00
Instructor
Instructor
The webcase you have opened is redundant and spurious.
The meaning of DIFF_TERM=TRUE/FALSE is already known, you already have the information you need.
The purpose of the webcase is to clean up the docs to make them more consistent and explicitly clear.
-- Bob Elkind
SIGNATURE:
Summary:
eteam00
Instructor
Instructor
Under Webcase #876157, Change Request (CR) #612035 has been created to clean up the docs involved in this 'mess'.
I have asked for a direct answer to the questions below, but have not (yet) received a response.
What does DIFF_TERM="TRUE" mean?  Are different values of diff termination available?
-- Bob Elkind
SIGNATURE:
Summary:
mcgett
Setting the value to TRUE enables the 100 ohm termination between the P and N sides of a differential pair.
Setting the vlaue to FALSE disables to the 100 ohm termination between the P and N sides of a differential pair.
No other options are available.
eteam00
Instructor
Instructor
Thanks, Ed.
Response from Webcase support tech matches Ed's description, exactly.  Here are some diagrams to accompany the description (which I suspect are excerpted from a Spartan-6 doc).
-- Bob Elkind
SIGNATURE:
Summary:
mcgett
Those diagrams are correct.
The first wih DIFF_TERM = FALSE shows an external 100 ohm terminator and nothing within the IBUFDS.
The second with DIFF_TERM = TRUE shows no external termination and an internal Rdt terminator within the IBUFDS.
