buddha1987
Voyager
Voyager
Is there any approach to clear the project open history in Vivado?
After we launch the Vivado, we can open the project in the starting page through "Open Project". When we click it, usually we have a list that shows some previous opened projects.
But I found a problem is the list seems not be updated very well. Sometimes I can't see the project I often open recently but the list still have the project I didn't open for a while.
So I wonder is there any approach to clear the project open history in Vivado?
Thanks in advance.
yenigal
You can also use the File->Open Recent Project->Clear List to clear all the recent projects.
Satish
vemulad
If you go to Tools --> options in vivado, you can see below
In Miscellaneous tab, there is a option "number of recent projects to list". Select 1 (minimum value alloed) here and click on OK.
Now reopen the options and set this back to value of 10. By this it deletes the history of opened projects. You can see only one recently opened project.
Hope this helps.
Deepika.
Deepika.
yenigal
Satish
buddha1987
Voyager
Voyager
Thanks very much, both of you.
