Is there any approach to create an IP in Vivado or ISE without a project?
In some cases, I just want to create a Xilinx IP, but I don't want to create a project. In this case, how can I create a IP without an open project?
Thanks in advance.
Scholar sampatd
Re: Is there any approach to create an IP in Vivado or ISE without a project?
You can use the non project mode in Vivado. For more information on working with IPs in non project mode, you can check page 55 of the following doc:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/ug892-vivado-design-flows-overview.pdf
See Lab-5 for the following user guide: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/ug939-vivado-designing-with-ip-tutorial.pdf
Did you check "manage IP" project?
The Vivado IDE can create a special project, referred to as a Manage IP project, which facilitates the management of IP customizations. From this project type, you can view the IP Catalog, customize IP, and generate output products. The IP customization (XCI) and generated output products are stored in separate directories located beside the Manage IP project. The Manage IP project manages the IP design runs for the generation of the Synthesized Design Checkpoint (DCP) files.
Refer to chapter-3 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_3/ug896-vivado-ip.pdf for more details.
Deepika.
Deepika.
