[Labtoolstcl 44-469] There is no current hw_target.
I have re-install the USB CABLE driver but it does not work. Is there anything else I could try to solve this problem?
Re: [Labtoolstcl 44-469] There is no current hw_target.
Hi @wyr121266
1. Which OS are you using?
2. If using windows, check the device manager to confirm that cable is detected properly
3. Are you using Digilent cable or platform usb cable II?
Vinay
Thank you for your reply.
1.I'm using Windows 7
2.Yes. It is detected properly.
3.Platform sub cable II.
please let us know the procedure/command you used to re-install the cable drivers. There are separate drivers for digilent and platform usb. Was the jtag working previously?
If this is the platform USB cable, check the LED indicator to see if this is a problem with the platform USB adaptor.
Anirudh
@wyr121266 Check if this helps
http://www.xilinx.com/support/answers/44397.html
-Pratham
Hi Anirudh,
Thank you for your help.
1. I first delete Jungo driver and Xilinx Cable driver from Device Manager. Then I uninstall Vivado Lab. Lastly, I install Vivado Lab with Cable Driver option checked.
2. The LED indicator on my Platform Cable USB II is on.
Zhaojian
Hi Zhaojian,
If you have re-installed the Vivado lab with cable drivers, i assume the cable drivers must have been installed correctly.
Is the light green or any other colour on the Cable? Check the pg 11 of this for led indications - http://www.xilinx.com/support/documentation/data_sheets/ds593.pdf
In addition cross check if the digilent cable (the micro usb) works if you have one.
If nothing works, then cross check the SI of the JTAG connections on your board, if this is a custom board.
Anirudh
I am using Ubuntu 16.04 LTS and have installed Xilinx’s Vivado HLS tool version 2016.4. With this I am getting the problem as follows:
                                     ERROR: [Labtoolstcl 44-469] There is no current hw_target.
Please help.
-Indranil
