rwarner174
Launching Web Pages from ISE, XPS, etc... in OpenSuse Linux
I was wondering if anyone has come across and come up with a solution to this problem?  I am using OpenSuse 11.4 with ISE Tools 13.1.  When I attempt to click on and error/warning link in ISE/XPS/SDK or any other tool I get the following error in the xterm in which I launched the tool:
Inconsistency detected by ld.so: dl-open.c: 582: _dl_open: Assertion `_dl_debug_initialize (0, args.nsid)->r_state == RT_CONSISTENT' failed!
I know this has something to do with what gets set when sourcing the settings64.sh file.  Specifilcly LD_LIBRARY_PATH.
Has anyone had this problem and come up with a solution to it?
rwarner174
Any help?  Am I the only one running opensuse 11.3 and using xilinx tools?
eteam00
Professor
Professor
Yeah, I imagine the herd using ISE 13.1 on opensuse 11.3 is still pretty thin.  ISE 13.1 is still pretty new.
-- Bob Elkind
SIGNATURE:
Summary:
rwarner174
Let me add more information.
This has happened with every version of ISE I can remember.
The error I get on the xterm where I launched ISE is the following:
Inconsistency detected by ld.so: dl-open.c: 582: _dl_open: Assertion '_dl_debug_initialize (0, args.nsid)->r_state == RT_CONSISTENT' failed!
This appears to have something with the settings64.sh script setting LD_LIBRARY_PATH.
I am using firefox as a browser.
I anyone has tackled this in the past, help would be appriciated.
astrobeppe
I'm just experiencing the same. Same envinonment, same error while installing 13.1 on a SuSe Linux 11.4, 64bit.
The Error rises when XLCM tries to open an existing Licence file.
Any idea, what's up?
