intrealm
Maintaining Network Nodes State
Hi there,
I have a client-server application that is made up of one central/server FPGA board and a network of nodes/clients of FPGA boards. It is a computational application. Each board is assigned a number from 1 to n (N can vary from 3 initial to 20 in the future).
The central board must send a message to all the boards to tell them to start performing computations and then must wait for all the boards to report that they finished the computations. Multiple boards should be able to report to the server in parallel/concurrently.
Can someone tell me how can I implement that in the main board? Should I use an array to maintain the state (sent-1, 0- not sent)?
Do I need a high-end board (~ $10,000) for the server or can I get away with a low-cost board? What is the recommendation?
Thank you very much.
Nick
rcingham
"Can someone tell me how can I implement that in the main board?"
How much are you paying per hour?
"If it don't work in simulation, it won't work on the board."
intrealm
How can I send a private message with this forum interface?
intrealm
Or maybe you can give me your email address and I will send you an email later on today.
intrealm
Found the link for private messages.
rcingham
My implied point is that for detailed and complex system design assistance, expecting free help in a forum dedicated to a specific vendor's technology is a bit unreasonable... If there is nobody in your organization who can solve that problem, you should start recruiting for such a person.
intrealm
I am not expecting free help, just looking for opinions from multiple people.
Perhaps we should just buy the boards without documentation, ask no questions, get no support, stop looking for example code which seems nowhere to be found, to help improve the vendor bottom line.
For sure.
eteam00
Professor
Professor
I am not expecting free help...
Of course you are expecting free help.  There's nothing wrong with that.  This forum is established to provide free help.
That's silly.
I suggest you start over.  Keep in mind that this is primarily a forum site for FPGA and product designers.  There are specific forums devoted to FPGA-based development boards, but these boards are designed first and foremost for developing FPGA designs and applications.
The description you posted lacks most of the detail required to compose a useful response.  If you are knowledgeable in the arts of hardware (and, specifically, FPGA) design, then you should be able to add enough specific details which will lead to a useful set of (more or less) specific suggestions.  The answers you get will be no better than the information you provide.
The application you describe sounds simple enough, given the absence of details.  Let's see where additional context and detail will lead the discussion.
-- Bob Elkind
SIGNATURE:
Summary:
intrealm
I did sent a private message to rcighan in which I was offering to pay for help.
First, I am scientist and I just started with FPGA a couple of weeks ago. Given that there is no subforum for Jobs I guess I thought of posting something under General Discussion.
Second we do a lot of differential equations (millions to start, a lot more down the road) and I must say that being unable to find an example of such a system on Xilinx site is quite surprising.
I'll find someone to give me another opinion. And I am going to check Altera for a change.
eteam00
Professor
Professor
If you go shopping for a design engineer on a FPGA manufacturer's website, the solution you end up with may very well be a custom board design with an FPGA on it.  Or it may be an off-the-shelf board with an FPGA on it.  You know the old saying:
'If the only tool you have is a hammer, all of your problems start looking like nails'
...or something like that.
I'm sure (and I hope) that you know more about your application's requirements than what you have yet described or disclosed.  Based on what little you've written, it may well be that your quickest and cheapest option would be to shop for a software developer rather than (in addition to a software developer) a hardware designer.  A network-connected windows (or Linux) PC sounds well suited to the 'main board' application, to the extent you have described.
-- Bob Elkind
SIGNATURE:
Summary:
eteam00
Professor
Professor
intrealm,
After reviewing your posting history, I agree that you would benefit from the services of a hardware designer.
-- Bob Elkind
SIGNATURE:
Summary:
