Visitor sjun027
Mearsuring CPU usage
Hi, there
I am currently developing a system on Zynq.
I would like to measure Hardware Usage(CPU)  while developing on SDK or Plan Ahead.
Any reply would be appreciated
thanks.
Scholar joelby
Re: Mearsuring CPU usage
Are you using an operating system on the Zynq? A CPU is always in use, unless it's in a sleep mode. If you're using an operating system, CPU usage is defined by the amount of time you spend doing something and not just waiting for the next task. Operating systems generally track these sorts of statistics for you.
Visitor sjun027
oh well i do not use os on the Zynq.
so you mean.. using some GetTime() functions between my code would give me the CPU usage?
Scholar joelby
Not quite, that'll give you the time it took to do certain functions.
CPU usage only makes sense in the context of a multi-tasking system (or perhaps if you're putting the CPU to sleep from time to time). It's up to you to define what is 'real' CPU usage and what is 'idle' (sitting in a busy loop, or a while(true){} loop and waiting for interrupts, etc.).
