princemmf
Middle states at transition moment
I implemented a 16-bit register to generate required data in my design. It should change from x”0000” to x”FFFF” at the rising edge of the global clock. I did the post-route simulation, finding out that at the rising edge there are a lot of middle states between x”0000” and x”FFFF”. This is causing a great trouble in my design. In the attachment is the picture showing specified waveforms!
How can I solve this problem?Thank you for your kind attention!
Prince Ma,
Harbin Institute of Technology,
P.R.China,
June.3rd.2009
jprovidenza
Voyager
Voyager
Briefly - you can't solve this problem.
In the real world, ie, post-route, the output of each flip flop follows a different routing path
to its destinations.  You can imagine that output Q1 drives input D1 and Q2 drives D2. Since
Q1, Q2, D1, and D2 are located in physically different locations on the silicon, the distances
between them are different.  Thus, if both Q1 and Q2 switch at the same time, D1 and D2
will see their inputs change at slightly different times due to the different routing delays.
In a synchronous design, as long as the routing delays are relatively small compared to the
clock period and setup/hold times, everything works fine.  If the routing delays become too
long, the design fails.
If you are decoding the bus value and using that to clock more logic, you've got a fundamentally
flawed design - you will probably have decode glitches.
On common technique used to work around this is to use Gray Coding - by design, only one
bit is allowed to change on each cycle.  This is an excellent way to avoid this problem and to
pass counter values from one clock domain to another.
Hope this helps!
John Providenza
mcgett
What you are seeing is normal for any FPGA or ASIC.  The differences in the transitions across the 16 bit bus is simply do to clock skew and net propogation delays (mostly net delays).
Timing analysis will guarantee that all of the propogation delays will meet the necessary set up and hold times to the next register in a synchronous system.
If you are transferring the data bus from one clock domain to another then you need a synchronizer circuit to ensure that all of the data has settled first before it is clocked into the next clock domain.
