mschreiber68
Module Propogation Delays
I have simulated a verilog design that used some propagation delays like:
and #20 (out, in1, in2);   (using #20 as 20 nanoseconds)
and the simulation works well. Now I want to implement these delays on a Spartan 3 board, but after going through the documentation I still can't get a handle on how to do that.
btw I'm using ISE 11 Web Pack
mschreiber68
I'm thinking of just using a timer from the on board 50 MHz clock, but now I'm wondering how can I access that clock in verilog? And I'm assuming 1/50MHz = 20ns is the shortest delay I can get?
drjohnsmith
sorry dont know verilog, we speak the other language over here,
but
You can not synthesise a delay into silicon. If you think of what the silicon would have to do, it would be a string of gates with a fixed delay.
You need to think syncronously, things happen on or because of a clock.
The Xilinx FPGA's have various DLL and PLL options, dependent upon the device , usefull amongst other things for making a faster internal clock.
You can also, if you are careful use both the rising and falling edge of a clcok, or even pahse shifts of a clock to get aparantly faster circuits.
As for how to acces the timer.
When you make the timer, it will have a counting register, you access that.
Can I suggest you start with a few on line tutorials, they might break you in tho this sort of thinking.
mcgett
Delay constructs in either VHDL or Verilog are not synthesizable into silicon they are intended for simulation purposes only.
If you have a clock that is 50 MHz (20ns) then you every register stage that is added will delay the signal by 1 clock period (20nS).
ninjamafiakhan3
#20 is a simulation construct...you can only have it working when in simulation software like ModelSim...if you read the stuff that the project navigator console prints out while synthesizing...if you something like #20 in your code it says that it is ignoring those delays...
If you want actual delays and dont want to use interrupts from timers (like, lets say in a MicroBlaze design) you can use something like this:
reg[25:0] count=0;
reg bit=0;
always@(posedge clk)
begin
count<=count+1;
if (count==50000000)
begin
count<=0;
end
end
always@(negedge count[25])
begin
bit<=~bit;
end
This will toggle the bit every 1 second on a 20ns (50MHz) clock like that on the Spartan 3 board...
