Part Availability request: Xilinx
I am currently evaluating our program’s part lists for availability/obsolescence issues and am in urgent need of your assistance.
Manufacturer Part Number
Manufacturer
Question #1
Question #2
Question #3
Question #4
Question #5
XCR3512XL12FT256I
XILINX INC
XC3S400-4FT256I
XILINX INC
XC2S200-5PQ208I
XILINX INC
XC2S200-5FG256I
XILINX INC
XC4VLX60-10FF668I
XILINX INC
XC4VLX25-10FF668I
XILINX INC
XC4VLX25-11SF363I
XILINX INC
XCF08PFS48C
XILINX INC
XC9536XL-10VQ64I
XILINX INC
XC3S1400AN-4FG484I4307
XILINX INC
Please review the part number(s) from past assessment and assist me by answering the following questions. Importantly if there are any changes.
For the item(s) listed above.
  1. Is this the correct and orderable P/N(s) (if not, please advise (any alternates?))?
  2. Are there any plans to discontinue the part(s) listed within the next two years?
  3. Is this part recommended for new designs, if not do you recommend an alternate?
  4. What is the current Termination finish of the part number(s) listed and their percent composition for each element of the termination finish (i.e. Tin/Lead 63/37% - 100% Pure Tin).
  5. Please Note: if the pin leads/surface contact to PCB are Gold Plate, please provide the plate thickness in mico-inches, and how the part is connected (i.e. contact or solder required)?
  6. If there are alternate finishes available;
  7. Denote their corresponding part numbers?
  8. What are their percent compositions?
Thank you
v/r
David
Where have you tried looking ?
To expand on @drjohnsmith's response, most of these questions should be asked of an authorized Xilinx distributor.  I think you will find that most of the parts you are asking about are discontinued.
I was referred to open a ticket here on website through service portal. All I seem to get directed to is posting on message board. My one contact for Xilinx is the one that referred me to here. I'm aware the parts are being discontinued, I'm accomlishing my normal 6 month review of Part's list, and just needing verification that no changes have occurred since my last report.
Were you refered here , or to the service centre ?
at the bottom here.
https://www.xilinx.com/support.html
I've tried to open a task through service center and everything directed me to the posts.
HI @dracdenn ,
Your FAE is the best contact to get these answers. I will try to ask him to answer.
Thank you, I'd appreciate that, but the POC I did have referred me here, and because the p/n's I'm asking about are older versions, it doesnt allow me to open a service ticket. Only option I get is to post here in forum for assistance.
d,
That is because your only real support is through your authorized distributor.   If you feel Xilinx has classified you incorrectly, you should open a service request.
l.e.o.
Hi @dracdenn
We have contacted your sales contact and asked him to reply to this questions directly. As per the Service Portal page, this type of questions are not supported through the Service Portal:
This is the same for the forums. You will not get these answers here.
For my informaton
who do yo unormaly purchase through
Hi @dracdenn ,
Just a quick check? Did you get the answers from your FAE?
Out of interest, who do you have purchase contract with ?
